lucadileta
Hello everyone,
I would like to ask you a problem that I have in creating a model of a drum cam. for a project of a cinematism I and my colleagues have created a cinematism through a drum cam. the problem we have encountered is that with the cads we have it is not possible to realize a model of the above cam correctly. Specifically we used solidworks 2016, the camtrax program and the new features "sweep cut" of nx 11 that allows for very simple path also to have intersecting cutting profiles. the problem is that none of these roads went along proved to be accurate. geometry has been verified with matlab is always different from a small but not negligible quantity.
At the end of all I believe that the only way is to create the model with a software that allows to reproduce the geometry by means of a cut for envelope that follows the process of milling the cam but sincerely I do not know
is anyone aware of such software? Maybe that also allows you to have intersecting cutting profiles?
thanks to all in advance
