inventor 2017 and memory ram
mir
Good morning.
I have a machine with 64 gb memory (intel xeon e5-2660 2.2 2.0 ghz) 64 bit and with 5,000 square nvidia ... a set of 39600 pieces a disaster to open and manage ... very slow .... but if I go to see the performance I don't even use 12 gb of ram (5 only inventor) and neither are the cpus stressed....
Do I need to set up something for you? advice?
video card from its panel highlighting performance and not appearance....you can set it for inventor and leave the general configuration of the board unchanged.
from inventor then you have to decrease the definition of the polygonal approximation of the circles, load view without solid edges.
If you can try not to solve geometry.
look that it is statistically normal that you do not allocate more than 12gb even if you have 64gb... me and xeon do not agree in fact.... I prefer processor i7 with high frequency.
Anyway, I think he's suffering a bit of the video card that might need a better driver to stay smooth and not go to snaps on so many elements.
a) what does statistically mean? I mean, just use a little bit
b) it is not that it goes to snaps ... it is slow to select the together ... to start the rotation ... it seems to use a very poor pc.
thanks to the tips I set them right away
hi mir!!! I try to give you a hand...
1) the fact that you have 64gb ram does not mean that your pc uses it all....
2)Set energy saving options on high performance.
3)disable intel speedstep from bios so true the most reactive cpu
4) how recommended mechanicalmg updates the drivers and performs the settings that recommended you
5)39600 parts are really many... load or work on small number blocks....e5-2660 v1 is poor as processor for this use (it has a maximum frequency of 3ghz against 44.5 of the current.... take an i7-4960x or a xeon e5-2687w), eye that for rebuiling a complex model like your cpu point speed is fundamental.
5) the 5000 picture however good in its time takes read from a firepro m6100 from notebook... just to give an idea
6) If you don't already have a ssd take one to speed up your ws
before you ever noticed slowdowns on the same model?
