ale1190
very often in doing a simulation wizard analysis, the error "mesh failed". interruption of analysis."
Therefore I click on "show areas where mesh failed". I'm stupidly saying, I'm running that part and I don't have a problem anymore.
But not... gate that processing ("casually" always the last of the tree) remakes the simulation eee... again problem on mesh.
regarding what is the problem and always "characterally" the problem has moved on the new last of the tree (after the cancellation of the previous).
so away until it lets me clear everything.
here is an image to better understand the error:
Okay. this perhaps is a somewhat complex structure (although often by mistake on much simpler details).
but if one has to verify such a structure what should he do?? already the fact that to be able to do this test, the structure must be drawn in a single block, creates several problems.. if it doesn't work. .
Is there anyone who has ever had such a problem or who explains the "trucks" to perform a correct simulation?
I also send you the original file, so if you want you can do some tests too.
View attachment Struttura.7zas I always trust in you.. :36_1_11:
Okay. this perhaps is a somewhat complex structure (although often by mistake on much simpler details).but if one has to verify such a structure what should he do?? already the fact that to be able to do this test, the structure must be drawn in a single block, creates several problems.. if it doesn't work. .
