paritetic elements in subassieme.
  • Thread starter Thread starter Davimont
Davimont
I put a sub together in a main set.
Now I want to make holes on the components of the under together by editing part but I can't intercept the edges of the details placed in the main axieme.
I have the option " paritetic elements" active and in options of if in the section "between the parts" I have all enabled.
I am on st8 but I noticed this problem even before.
Can you tell me why this behavior is, and if I have to enable something?
have you tried to upgrade all levels and make its rescue? all active parts?
Are the parts you want to intercept the edges active?
then starting from new files I can't replicate the problem.
Unfortunately I can't attach the file that creates anomaly to me but I think it's a problem of lost and settled links somehow. the axieme among other things was created with an old version of if and has undergone several saves by name.
in this case I made the holes by quotating them at the holes below. Obviously in case of modifications to the drill below will not update automatically but I will have to do to handle.
from the tool menu select the "interpart manager" command from them you should be able to see the broken links and delete them or to the hand understand what to intervene.
I've already checked the entire connections and they're intact.
I can't waste any more time for today, but I'll do more tests on the next occasion.
Thank you, Frank.
Thank you, Frank.
You should not check if they are integral, but if they aim at different assemblies, as a "accept" part ties to a single set, if there are only already defined to another set, you can not add others to another together.
the under together has two sketches inside and on those sketches were built 4 pieces of sheet metal therefore each single piece points to the under together.
so if I insert that under together into a top set I can not use the edge detection:confused:
no, in case you described it works; what you can't do is have within the same file (along or part that doesn't matter) links to parts in different contexts, I explain:
together with, mount part b and modifying it create links with other parts contained in the axieme a.
c, change the b part by changing it you can not create links to other parts contained in the axieme c because you already have links within the axieme a.
If you open the sheets you want to drill using the highest level axieme, and see that they have links with the axieme that contains them, then what is required you can't do.
That's right. the single sheet already has a connection to the axieme that contains it because it points to the sketch (made together) that then generates it.
then you can't connect your sheet to a set other than the axieme that contains it.
