software e laser,grosso problema
  • Thread starter Thread starter maxnumero1
maxnumero1
Hello everyone, I have a problem
I'm a laser cutting machine, I need to cut sheets that can be assembled once you're down.
in practice I have to insert a 300mm tube of diameter sideways to another tube
so I would like to shape a sheet that once calandrated (becomes a tube) fit perfectly with the larger tube
I hope to have explained, no complicated, but:
which software to use?
I don't think it's anything complicated, but with all the software I've got, I can't find what happens to me.
you have to use a cad that allows to make the developments of the sheets (solidworks, solidedge, inventor, create, etc.) . models the tubes that intersect and then develop them.
thank you 1000 for the answer
These programs create all dwg files?
which of these is the easiest?
autodesk inventor fusion does the thing I asked for?
all software intersect solids, but do not know which ones are able to lay down to create a 2d drawing of the piece
all manage the sheets and their development. a three-dimensional cad that knew how to do it would have short life
among those who have been proposed
and you asked about
He is not appointed autocad.
I do not know the 3d environment of autocad, but I am quite doubtful that it can make automatic development of a sheet
the fact of asking on a forum if a certain software has the functions such of, losing a lot of time waiting for the answer that might also not arrive, such remains one of the unfathomable mysteries of the past and present millennium.
there must be some logical engulf in reasoning that prevents you from coming to mind to go peek at the site of the manufacturer, site that has been set up to sound tens of thousands of dollars just to answer those questions too.https://www.autodesk.com/products/fusion-360/compare :smile:
you have 1000 rotten reasons,the problem is that I do not know how to call this function or command or procedure,which allows to lay a tube after having shaped it
Maybe if you would help me understand by what name I can do a search, but I will solve by myself
