sono io
Good morning, everyone.
I would have a little problem with the couplings in solidworks 2017 sp0:
View attachment Assieme GN_187_4.rarin the attached file there is a small set (a rotary clamping element) with the correct couplings (pense) where only the external disk has the possibility to rotate.
when I take this (under)assieme, inserting it inside a larger set, the flexible Irrew to be able to use the free movement of rotation and the couplings of this "pack" going to create couplings (for example between nonconcentric holes) that I did not.
I have read on a previous discussion that all the components must not be fixed but the result does not change.
What am I wrong?
thanks 1000 for the collaboration
What am I wrong?
