problem with restraint that does not iron
I found a problem with a restraint, usually if pulling from the grip stretches into the file that I allego can't like why?View attachment 49369
analyzing the design were not associated with 'reactors' to the object, that is - to understand - invisible constraints to another object present in the drawing.
seems more than anything else a strange bug linked to the solid sample model, in fact changing model everything goes to place... then remittaching the solid model is no longer generated.
the only way to use the grip seems to recreate the edges with _hatchedit and make them associative.
when selecting the grips you have to be careful to select those of the right entities as 5 polylines and 4 splines are created and not a single polyline.
First of all thank you for having found time to look at it. I do the same to myself. be so ok normal will be the complex goemetries.
the problem comes from the initial contour of the dash, combined with the solid
the curve is composed of 2 spline (beginning and fine) and a pline in the central section
if you convert the 2 spline the beads and joins all the contour in a single polylinea, the dash of this (new) area is quietly editable even with the solid.
Thank you very much for looking at us!
