auminenting miniature su anterior solidworks
  • Thread starter Thread starter bibi9000
bibi9000
I checked on the network and also on the guide
point 1 I see thumbnails of very tiny solidworks parts if I zoom in preview thumbnails disappear
point 2 not all are displayed when running the command open
Question: How do I see larger thumbnails when I run the command open?
thanks to everyone hello
Yes....from you are immense....if the magnify you can no longer see anything
press ctrl and scroll with the wheel (holding ctrl) after pressing on the window that interests you, I don't know if you have already tried it but you never know
that I tried... it's the same thing by setting from the drop-down menu... beyond a certain size you can't see image anymore and on some you can't see even if it's small
I don't know how to help you, sure that's not a hardware/software problem with your pc?
Have you tried on other locations? (if you have any. . . )
:36_1_13: found .... in folder options....view....I took the check always shows icons never previews.... I could see pictures of the pieces with gigantic previews.
