peloritano
in our company after working a surface with an operation that we call finishing we pass to the processing of channels, in fact if the finishing operation has been carried out with a 10mm radius spherical milling it is normal to think that, if there are channels whose radius is <10mm, they can not be processed in the finishing operation as the tool does not enter you inside.
to obviate to this we carry out the recovery operation by passing the cutters away by a smaller radius (rough 5 4 3 2 1.5).
catia (as well as all other cam software) provides the shooting area command (see imm1) that virtually analyzes the surface by identifying the various channels to work. .
in the screen that opens (visible in imm2) the various parameters are set like the surface to work, any limits and offset on the surface itself)....
the problem that happens often consists in the fact that the channels are not perfectly regular (channels with constant radius) but can present some small imperfections. . .
catia in this case is very sensitive and pignolo and goes to identify between the channels that make up the surface only those whose radius corresponds to the one required.... if the channel is not regular often happens the problem visible in imm2 i.e., are selected of the dotted areas. ...
If processing on the finished piece is now going to appear unsightly processes.....
tebis from this point of view is phenomenal because it allows manually to combine all these traits by making sure that the tool always remains in contact with the surface and working the channel for all its length, in this way you get an aesthetically excellent result. ...
I discovered that by changing the visible paramentro in imm3 all the traits identified before are now united with a single curve... So in this case, the channel is worked without that unexplained deduction effect.
The question I ask is the following....
what exactly does the parameter indicated in imm3 serve?? I followed a caty course and of course it is unthinkable that my instructor could have explained to me by thread and by sign all the vestments of all the work that it is possible to create with catechism... Since the assistance has gone (the crisis has made us cut all the expenses) I ask you if there is anyone who can explain the meaning and function of the various vestments of this hateful processing
