problem color layer in the layout space
  • Thread starter Thread starter pc3103
pc3103
I created a combination of two solids in autocad and the part of "intersection", created with the interference tool, I colored it in red (in the model space). the problem is that when I go into the layout space and create the views (through the basic-space model option) the intersection layer (red colored) you see black. I checked the layer management and nothing is frozen. What is the problem?
Thank you very much
hi, to create the views I used within the layout section the basic/space model command and automatically I had the projections.
base/space model is not a command. Maybe a sequence.. .
I do not use the 3d autocad and I do not know the commands; Can you tell me the command name to be typed in the command bar or the exact sequence with the name of cards or groups to get there?
in the layout/group view/base drop-down menu/from the model space. Sorry I wasn't accurate.
the following message:impossible to load inventor servers.
Is it not that it only works if you also have inventor?
I don't have inventor. in the drop-down menu of the basic text is present both "from the model space" and "from the inventor". sure you clicked well?
Of course I'm sure. .
as it may not be correct the commands relative to the icons you can tell me that command vine launched with that from the model space? to me is equal to vista base
I'm sorry, but now I have no way to see. but it seems to me (it seems) that I also correspond to basic view, also because when you click it creates the basic view and then the others.
However I found the same problem described on an English forum and on two occasions say that you have to remove the check on "display plot styles" from the page management settings. tomorrow I try and see if the problem is resolved.
to me it works well, in the sense that I see it red in the wireframe model, but being completely incorporated into other 2 solids, probably in the press will come out all black...
delete the pentagonal prism and the cone and see what happens.
Hi tristan,
The thing is, I don't have inventor, so I don't understand why that message comes out.
since looking in which the command corresponds to the icon to create the views I did not find useful matches and assuming that the command vista base that is launched was not the correct one I asked that it be specified.
you say that a server inventor folder is created? I'll take a look.
Hello, then the command is seenbase. I tried to remove the tick on "show print styles" but the problem is not resolved.
for crystal, I also see perfectly in the model space, the problem is in the layout space. I tried to leave only the lines of interference, but still remain black.
Okay, guys, I got it. I practically did something useless. Once you create the basic views, there is the option to show or not the interference edges. activating it I changed color to the two layers that created (visible/hidden) and solved. Thank you very much
