DANI-3D
copy geometry I can only do parts where I first created public geometry, not selecting the component with the procedure you indicated before, and the public geometry I can only do it at part level, not in a set.
Yes it is true, I must admit that the geometry copy I have always used it little, and always combined with the public geometry.mmmm maybe there are misunderstandings.
Okay. All clear. Unfortunately I cannot use the geometry copy to solve the problem of mirroring the axiemi, because there are too many pieces, I have numerous reinforcement handkerchiefs, inserted with series, which I dare not think of dealing with the geometry copy.Yes, the copy geometri is specific to one component (that's why I said it's laborious if you have so many components), but you're free to put all the copy geometry you want for the same component (and decide its update)
I have used this method for many projects in the past, with excellent results. in some cases the packaging with mirroring requires less preparation, apart from the numerous regenerations and refreshes shrinkwrap.... for this step, I prefer to use the skeleton for positioning and make copies mirrored in support assemblies...
