lorenzocalo
hi to all, I ask you a hand in the realization of a transngente belt to extruded. the belt has a rectangular base and, as soft as it is made of nylon, must follow the body (extruded pink) starting from the tangency to the curved area.
the problem is that I can't create the bribe bond. I created an offset geometry from the extruded profile and used such geometry as extrusion / sweep path of the rectangular belt base.
the problem I think lies in the offset geomatria. the strap has spent 3 mm. what do you recommend me to do?
