Good evening to all,
Could someone help me get the development on a floor of the attached tank?
I tried to use the command "develop in the plane", but the figure comes out with a larger surface and not circular.
No. the edge is an open circle of diam. 3mm
Thank you in advance.
Thank you in advance.View attachment 49807
Good morning.
thanks to the generative sheetmetal design package, I managed to create the tray and also make the development plan with the command "piega/sviluppa in piano. But now another problem has arisen: sheet thickness is 0.8mm and I need to develop the sheet thickness axis (at 0.4mm). Would anyone tell me how to do that?
