andreaf93
good evening, when you have a set in which there are flexible components (so that they have couplings that define only a position or concentricity ensuring a swing or however the movement you need) is normal that these components are subdefined?
I make a practical example: Let's imagine a system like that of the photo, the pinions are well positioned the idem belt and the shirts are all coupled with the belt itself.
the only movement is the normal rotation of the pinions and as a result of the mesh along the path of the belt, as you notice however all the pinions and all the repetitions of the mesh are under defined.
