tilted and curved flat milling
  • Thread starter Thread starter Cadscarso96
Cadscarso96
Hello, everyone! I need to know how to make a fresatu on a tilted and curved plane, I tried with spline command and swing but I can't... advice?
the result "migloiore" that I got the allego in photo, I got it with bouncing command but remains material at the ends of the milling... someone who can advise me? Thank you!
I'm in the first place.
You can do it with a normal extrusion.
create a plan where you want to have your "cold", project the intersection of the geometry of the piece on the floor, create the offset for the depth, extend a little out of the piece and the game is done.
How do I project the intersection of the geometry of the piece on the plane? Thank you!
Something wrong. How do you work to do that sketch?
I create the plan, design a rectangle longer than the base of the piece and use the bouncing command but it gives me error. the message says: "unsuccessful bounce. profiles extend beyond the body. "
Yes, the bounce projects the sketch on a surface, if the sketch comes out from the same does not know how to project.
I would work with a pipe (I don't remember the exact name of the command), do the sketch on the sloping surface projecting a straight, then normal to that sketch create another sketch with the section and do the pipe removing material.
or do with the method I wrote you in the previous post.
