weight in separate cut
  • Thread starter Thread starter skia51
bhé if you say how you tried you can correct it, otherwise I have finished mystical visions and are waiting for charging
:roflmao::roflmao:...you forgive me you are right.
Then I will explain to you step by step as I have tried:
- I opened the sheet to make a part
- I designed a tubular with the structural member function.
- dx key on the welding/property distinction icon (image-1)
- I added the line of interest n°8 weight etc (image-2)
- I saved the part file as .prtdot
- did this, I opened the prtdot file, I deleted the structural member function and sketch and I saved again as prtdot
Where am I wrong?
mistakes because it is obvious that if you change the properties of an element, when you delete it these are eliminated.
There is no need to create a structural element.
it is necessary to create the distinct by activating the welds with. insert>salda
then in the feature manager click on the soldering icon and change the properties
I did as suggested and I attach the screen that comes out to me when I click on the soldering icon plus properties.
Why is it empty?
What do I do?
Forgive me but here I have lost:unsure:
because default is empty. Always. the lines you insert are always propagated to all the voices of the separate cut.
Just make a try: open a part with separate cut already present and compiled, click on this soldering icon and you will find it empty, add us a random but recognizable property and then go to look at all the items of the separate cut... You'll always find the one you just added.
so you have two ways:
1 add the weight property in the template as explained above
2 add the weight property to all library profiles
explanation more than clear.
I used solution No. 1 and now everything works.
based on your experience, what do you think is best to do? solution 1 or 2?
