center line drilling table.
  • Thread starter Thread starter New Rider
New Rider
Bye, guys.
Suppose we have a 100x100 mm plate on which we have to make 4 holes arranged at 25,00mm from each single edge. using the drilling table I am asked to insert the coordinate x;y that is usually placed on top or bottom left in the top of the plate. I would like to create the drilling table using the center line inserted in the two half-mills of the plate. the table does not allow to insert fictitious axes or other. Am I wrong? Thank you.
guiarda that under the coordinates you have the source box. that also takes the sketches
Hello massive nothing to do. then I re-tryed to insert both a point and a origin and in the mask of the drilling table give “origin” does not accept it. the only thing that accepts is the center of a hole made right in the center plate . then takes its center that is also the center of the plate but I find 5 holes then.. I can't understand
