cinematism that does not move well
  • Thread starter Thread starter windreef
windreef
I have done this cam box, however, when I am holding the rotation constraint of the cam, the biella follows the cam, the sympathetic gear to the biella moves but the gear conduit remains firm. I have put the reverse rotation bond to the gears and if I move only they work, even if I move the biella . but if I call the cam the last gear remains firm. I don't understand where I'm wrong.
Thank you very much
Good morning, did anyone have time to take a look? even to know if it does the same to you too, I would not like to be the little powerful pc:
i7 4790
16gb ram
picture k2000
Thank you very much
hi windreff, I'm not an export of animations, but I think it's a limit of inventor, I don't think it's a moat properly moving the cam, I had already tried in the past too with a similar application and I never succeeded, but we wait for someone more expert to say his
Hello
Thanks for the answer.
I also never use cinematisms because in the past I had problems with movements but of a much more complex system the fact is that sometimes it went sometimes no but having inventor 2010 I thought it would depend precisely on a limit of the program but I see that with years some problems remain
I'm sorry, but with the version I use I can't open your project.
There is no problem thanks to the same.
I could save it in an older version but I'm afraid that then you add problems and lose time unnecessarily. Thank you.
I also behave in the same way, it is not a problem of pc.
I also tried to change the constraints but nothing changes.
Thank you very much
I couldn't have changed my PC right now. if it is a software patience bug.
thanks again to all
