macro-tutorial-examples for solid edge
invitation to attach a png/jpg view of the solid edge files that you share, to fly readers
Good morning, guys.
Given that I am not a macro programmer and after removing all the various sections and finding nothing, I decided to write. . .
There is a macro in the draft environment to save by button in dwg. we installed st9 here where I work and we would need to be able to automate export.
Thank you in advance!
Good morning, I'm here again to request a macro. we need to save every time I set up or open a draft with automatism pdf and dwg in an entirely automatic way. By automatic I mean that when you ask me you want to save and I say you automatically write to me the relative files in the dir of relevance where the father document resides in case they are existing I am asked to subwrite or make automatic the overwrite process. in our technical office my boss would also be willing to pay naturally. Thank you.
the solidrules addin does it
This type of operation can be managed via a pdm-plm, which manages the drawing database.
in the previous job we managed it with custom on teamcenter.
I'm sorry.
I also wanted to report another site where there are some macros.http://www.cadvertex.com/download.htm some are old and in the latest versions of if they are available with similar and optimized commands.
I would also have a request, I was looking for a macro that records, (on expressions or properties) the clutter of a piece.
Ever come up with this guy's request?
thank you
Hey, everybody.
I downloaded the macro to open the dfts having a part or axis already open.
the only problem is that when I launch the macro, it opens me the dft but in ''inactive' mode.
how can I do to open it in normal mode. . .
Hey, everybody.
from st10 onwards this function is already present in data management integrated in solid edge.
Hey, everybody.
seemed to have reloaded the modified macro to open the default active dfts.
if you have the previous version, by clicking "open dft" with the shift button(or maybe it was alt?) pressed opens the dft with active views.
domani provo ... grazie
hello, do you know if there is (or if you can create) a macro that highlights all "forced" odds (i.e. those odds to which someone has removed the real value to write one that more 'agads')?
with default settings, the forced value is represented underlined.
someone sets solid edge so as not to make this underline appear but it is as much wrong as you can do.
Unfortunately the genes of evil know a lot! I find quotas with empty value (picture below) to which a prefix was added... No stress. . the problem has been circumvented... and I find myself with not knowing how many drawings in this situation, for that I asked the macro
in the macro you have to take into account all the ways that exist to force the value o_o
I am not experienced, but I have tried to understand how they did and always gave me the underlined quota, apart in this way; I thought it was enough to make a filter that searched the odds with empty value the red color axis.
Obviously if one leaves the blank quota and writes the hand value with text box, the written text is not colored, but the quota is.
with the control of if (the one with the quotas underlined) and is macro should not be impossible to catch much of the cheats.
Did I miss any chances?
Get me back here! I had an idea: a macro that pressure the button steps (in psm environment) from the folded (3d) to the developed (always 3d). I tried to understand something through spy, but honestly I couldn't find the command that brings me back to the ordinary and true honor I found only the numerical command (45066) that passes me to the developed. someone who can help me?
