problem lentezza solidworks 2018 sp5
  • Thread starter Thread starter GiovanniSchillaci
GiovanniSchillaci
Good morning, everyone. Doing that even assistance is lost...after installing the 2018 sp5 I have the pc that goes less than a snail... every click I go to drink a coffee... am I the only one??? if it were so far ahead of the competition...
to me that version turns well, notebook fujitsu win7 64 sp1 with 8 gb ram, how much ram do you have?
but you cannot give an answer if you do not have a new minimum of context.
What are you doing? a bevel on a plate or a drawing from 1000 pieces and dozens of views? Did you do a function statistics? have you optimized system options? are the same options as the previous version? in the previous version you did an identical or very similar job and you have a match?
I'm working on a set, about 250 pieces. are the same as before the update. the project is the same
work with only one view at a time, I have a laptop with picture card 600, the options are exactly the same, I never touch something that is okay.. the problem arises when I touch a particular for mating, to move it, or to measure. often and willingly calls me quotas, despite no filter is set. in few words all commands are delayed, sometimes even several seconds
try reinstalling with all the necessary shortcomings for correct installation... It's very strange that you do so white. strange assistance that didn't tell you that you need to reinstall. I recommend you call them and reinstall while you are connected with them.
Thank you. I try Saturday to make a clean reinstallation. assistance is painful.. they opened a ticket months ago for another problem and never answered. I'm looking for a more seris company, but this is another speech
I know it's a trivial answer, but did you try to restore the video drivers to the version provided by the pc manufacturer, or update them to the latest version released by the nvidia?
Good morning. I used the verification tool and it's all right for him. I have not tried to update, as the system itself searches for updates and if you find it installs them
some questions:
-The final mathematicians are all stuck in read-only?
-the majority of these mathematicians, with which version of sw were made?
When you slow down a lot, did you try to do ctrl+q?
some questions:
I've been using it for about a year and basically, so I ask you a question, what do you mean by mathematics? constraints? even if I've never had these problems. all the project was made with the 2018 version, the same that I use but from another pc. I know that my friend has the sp0 because he does not want to update.
I tried ctrl-q but nothing changes. What does this command do?
thank you all again for the answers
for "mathematics" are usually 3d models.
ctrl+q is the top-level overall regeneration command (all is regenerated).
it happens that with mathematicians made with very old versions of solidworks, even if they are updated to the current, remain algorithms that are bad to marry with the current version, which also generates problems of slowing and slow graphics (from me we are subject to unfortunately); with the ctrl+q regenerates everything and the program regains speed and performance graphics, unfortunately, however, to the rescue, these algorithms are not replaced and therefore the problem reproposes to every rescue and every opening; who distributes sw recommends to remake even the starting templates at least every 2-3 releases and limit copies of very old maths.
You are absolutely sure All were mathematicians made with 2018?
the oldest dates back to the sw2016. I had done it before I bought the license 2018. The thing that leaves me puzzled is that on the work that I did directly with this version has no problem. (I'm trying) this project was started by another person with 2018, but at this point I have serious doubts that it recovered from inventor and then converted.
a good starting point is to retrace the mathematics with the conversion tool and bring them to 2018.
This is a good tip. Do you know where I can find him? as I told you I'm not very specialist, I just design it.. .
if they are converted by another modeler should not have functions.
if it has functions should be almost all subdefined
Did you do the analysis of function statistics?
in post #5 you say it's the same project you used in the previous version and before it didn't bother you; Now you say it's a project started by another person. Can you explain the situation better?
very simple. the project had been started by me, then transferred to another person who for his convenience had done it in inventor, which I didn't like. and was remade in solidworks 2018 sp0.
rebuilding everything after months is not as simple as one who does it every day...all here.
I am trying the other projects done before and I do not detect these problems, idem for the pointer who calls the odds at every click on the object. So I think it's a real problem.
Here. see that it has nothing to do with the sp5 version.
Who did that again? you or others?
What does that mean? you did it in solidworks, you passed it to someone who did it in inventor (from zero I suppose) and now you have it, you or others, made in solid from scratch? or are you all working on imported parts from step/iges? in case, you have converted the steps with recognition functions and find yourself with a mass of subdefined sketches and dozens of functions without logic?
