mozzaaa7
Good evening,
I have a problem with the sizing of an electric motor, especially the final transmission ratio between it and the wheels. below in the attached file "cartel1.pdf" are the engine data. the same will be mounted directly to a reducer that will transmit the bike to the wheels. the rear traction car has a mass of 1300 kg ca with wheel diameter = 610 mm.
two engines of 5 kw each and the car will have to be able to reach a speed of 85 km/h on the floor and exceed a slope of 22%.
the pair will then be doubled but the engines will have the same sync speed.
My doubts are:
how do I find the couple necessary to overcome this slope?
What is the transmission ratio from the motor to the wheels?
I would also like to comment on the correct reading of the table which I have attached and the values contained in it, not all of us are clear.
thanks in advance
My doubts are:
thanks in advance
