origins different parts from origin together
  • Thread starter Thread starter alde67
alde67
good morning to all, I always happen to find an error of centering of origin (ten millimeters) between the parts and the assieme, all this despite I am well careful in creating the sketches of the parts starting exactly from the center of the coordinates.
example (difference between floors 4,655mm - to the left floor together, to the right floor part):1552558422287.webp1552558460920.webpAny idea about the unconscious error I make?
It better explain what happens to you.
You create the part drawing on the origin, right?
Then you're going to put the part in a set? as the bond?
I create the first part in the axieme, and I find it fixed automatically.
note well: maybe I understood: I thought there was a tick on position and fix the first component, but there was no tick.... .
I checked the positioned and fixed voice, but already in the sketch phase I see that the origin of the part is decentralized compared to the axieme (you see the offset xz plan - to the left the xz plan of the axieme)
when you create the part as the positions?
you have to define his point of origin.
Now I have parts that have center not aligned with origin together.
Is there any way to change them?
if you have not selected anything but only the sketch plan should be free, you can bind them with the classic method.
Unfortunately I have bound the sketch to the origin of the part, which is not centered on the origin together.1552577165589.webp
I don't see the problem, if you move the origin of the part, the sketch goes after him.
