as I wrote no. the section is not right1) Are the views I put right?
no because no is clear what you want to communicate. if there are different holes, they must be rendered indisputable.I repeated the part of diameter 25.6 because they are 2 hollow holes and 2 blades, is it not correct?
This means that you have to quote the eccentricity of the hole center and not that you have to quota the radius.3) I have listed the rays because the cut is 0.2*d from the center
What's the question?Why do you ask for help if you don't follow how much you are advised and explained?
Good morning, I quoted the holes in width compared to the axis and arranged the views, I can't quota the diameters in "eccentricity" as he said massive, do I have to quote the distance between the ends of the circles?I see so much confusion, and I think so many basic concepts are not clear.
if the objective of the exercise is to give evidence to know how to model starting from the image in the isometric view provided, we may be
if instead it is to create a functional table ...
speaking in general seems to me that, as often happens to those who start, you want to give too much information on certain points and then neglect fundamental data in the quotation of the drawing. So before I put the tolerances (the geometric ones, then...) I would start with dismarcating the basic concepts.
for example: only in the second table is the width (95 and broken). but in no table I see the total quota, including the 2 " fins". will they be the same? will they be symmetric compared to the cl? will they be different?
I hope that the criticisms will be made constructively
ps just yesterday I passed from the bookstore hoepli and I saw a text that practically contained only practical examples of technical drawings of various components, and it was also well done.
It would serve as bread.
Unfortunately I do not find, even on the site of the editor, the reference. I'll mark them next time.
are symmetries, should I remove a passing section for the holes?this unfortunately you may know only that you have seen; but I point out that the previous section did not have the sampling so I think it was not a section.then I do not understand why the section now called "q-q" deep now gives me the view vertically, first with the same method put it up and horizontally.
it does not seem difficult; read your second table, look for the quota 95 (you have put a few will be easy) and you will find that the definition of the surrounding geometry is missing (the fins as specified by ironmike. Moreover that quota is wrong because it is a circle arc so goes the symbol of diameter.I don't know what you mean with "95" can you be clearer?
