export "automatic" idw to pdf-dxf
  • Thread starter Thread starter lollo76
for the problem that "zippa", you must for once export manually with the command:
file - export - export to dwg, select dwg for autocad, select options and turn off the pack&go optionsalva dwg autocad.webp
@catcher, please know your great availability. :
I would like to know, if it is not to ask too much, how to set a particular configuration for exporting dwg, see image
1651581963471.webpI'm currently working with this code (I don't need the storage number and the dwf so I commented them)
public sub pubblica() ' obtain reference to drawing dim odoc as document set odoc = thisapplication.activedocument ' destination folder ' --------------------------------------------------- dim sexportpath as string sexportpath = "c:\users\a.botticini\desktop\#esportati_dwg-pdf\" ' --------------------------------------------------- if odoc.documenttype <> kdrawingdocumentobject then msgbox ("deve essere aperta una tavola") exit sub end if ' get the filename with no path dim sfilename as string sfilename = sexportpath & isolanome(odoc.fullfilename, true) ' numero di revisione dim srev as string srev = inputbox("revisione tavola? ", "inserisci numero di revisione", "00") 'legge le iproperties personalizzate: '------------------------------------------------------------------------------------------------------- dim opropsets as propertysets set opropsets = odoc.propertysets 'custom '------------------------------------------------------------------------------------------------------- dim ocustompropset as propertyset set ocustompropset = opropsets.item("{d5cdd505-2e9c-101b-9397-08002b2cf9ae}") on error resume next dim scod as string ' sostituire "codice" con il nome che si usa per l'iproperty che interessa 'scod = ocustompropset.item("codice").value ' if scod = "" then ' scod = inputbox("codice ricambio (inserimento manuale):? ", "inserimento manuale codice ricambio") ' end if sfilename = sfilename & "_rev" & srev '& " (" & scod & ")" ' get the dwg translator add-in. dim dwgaddin as translatoraddin set dwgaddin = thisapplication.applicationaddins.itembyid("{c24e3ac2-122e-11d5-8e91-0010b541cd80}") ' get the dxf translator add-in. dim dxfaddin as translatoraddin set dxfaddin = thisapplication.applicationaddins.itembyid("{c24e3ac4-122e-11d5-8e91-0010b541cd80}") ' get the pdf translator add-in. dim pdfaddin as translatoraddin set pdfaddin = thisapplication.applicationaddins.itembyid("{0ac6fd96-2f4d-42ce-8be0-8aea580399e4}") dim strinifile as string ' common init ' create a context object dim ocontext as translationcontext set ocontext = thisapplication.transientobjects.createtranslationcontext ocontext.type = kfilebrowseiomechanism ' create a namevaluemap object dim ooptions as namevaluemap set ooptions = thisapplication.transientobjects.createnamevaluemap ' create a datamedium object dim odatamedium as datamedium set odatamedium = thisapplication.transientobjects.createdatamedium ' --------------------------------------------------------------------------- ' dwg ' ------------------------------- ' check whether the translator has 'savecopyas' options if dwgaddin.hassavecopyasoptions(odoc, ocontext, ooptions) then ' file with exportation options strinifile = "c:\tempdwgout.ini" ' create the name-value that specifies the ini file to use. ooptions.value("export_acad_inifile") = strinifile end if 'set the destination file name odatamedium.filename = sfilename & ".dwg" 'publish document. call dwgaddin.savecopyas(odoc, ocontext, ooptions, odatamedium) ' ------------------------------- ' fine dwg ' --------------------------------------------------------------------------- ' --------------------------------------------------------------------------- ' dxf ' ------------------------------- ' check whether the translator has 'savecopyas' options ' if dxfaddin.hassavecopyasoptions(odoc, ocontext, ooptions) then ' ' ' file with exportation options ' strinifile = "c:\tempdxfout.ini" ' ' ' create the name-value that specifies the ini file to use. ' ooptions.value("export_acad_inifile") = strinifile ' end if ' ' 'set the destination file name ' odatamedium.filename = sfilename & ".dxf" ' ' 'publish document. ' call dxfaddin.savecopyas(odoc, ocontext, ooptions, odatamedium) ' ------------------------------- ' fine dxf ' --------------------------------------------------------------------------- ' --------------------------------------------------------------------------- ' pdf ' ------------------------------- ' check whether the translator has 'savecopyas' options if pdfaddin.hassavecopyasoptions(odoc, ocontext, ooptions) then ' options for drawings... ooptions.value("all_color_as_black") = 1 'ooptions.value("remove_line_weights") = 0 'ooptions.value("vector_resolution") = 400 'ooptions.value("sheet_range") = kprintallsheets 'ooptions.value("custom_begin_sheet") = 2 'ooptions.value("custom_end_sheet") = 4 end if 'set the destination file name odatamedium.filename = sfilename & ".pdf" 'publish document. call pdfaddin.savecopyas(odoc, ocontext, ooptions, odatamedium) ' ------------------------------- ' fine pdf ' --------------------------------------------------------------------------- end sub 'funzione che restituisce il nome del file togliendo il path ed il suffisso public function isolanome(byval nomefile as string, optional trunc as boolean) as string 'toglie il .ipt if trunc = true then nomefile = strings.left(nomefile, len(nomefile) - 4) end if dim pos as integer 'ciclo che rimuove il path: trova "\" e tiene tutto a dx do pos = instr(nomefile, "\") nomefile = strings.right(nomefile, len(nomefile) - pos) loop until pos = 0 isolanome = nomefile end function
hi to everyone, I recommend taking a look at st-boosters, I'm finding myself well with this
View attachment 65456I'm currently working with this code (I don't need the storage number and the dwf so I commented them)
to be able to choose the configuration you must save it first, in the next screen to that post there is the "Save Configuration" button obviously once you set everything as you want. in the drop-down menu, there is also your configuration and if you save with that set configuration you will remain default until you change.
