exxon
yesterday I had six interviews for the selection of a junior mechanical designer to be included in a company in Verona. the candidates were:
1. mechanical expert with 5 years of experience as a designer/projectist;
2. three-year engineer mechatronic graduate;
3. three-year mechanical engineer with 1 year quality office experience;
4. three-year mechanical engineer graduate;
5. mechanical master engineer graduate;
6. Mechanical master engineer with experience only in non-binding sectors.
I asked everyone the same question about a simple exercise that I bring back below, obtaining a result that left me base. I would like others in the community to try to answer to see if the result obtained yesterday is a fortuitous case or not.
test:
Note 1: exercise is exactly as trivial as it appears. There are no tricks or hidden details that need strange inventions. the simple calculation necessary can be carried out in mind, without the use of any instrument.
Note 2: who wants to post the answer, answer only yes or no, without (at the moment) justify it, so as to leave to others the possibility to try without conditioning.
test:
a f, inextensible and negligible mass wire, is stretched vertically between the fixed point or the p, indeformable, and also of negligible mass. the piattello supports the fixed support s, held in position from the initial voltage of the wire pairs to 2 n. if the wire can with maximum a voltage of 100 n, will hold an additional weight of 10 kg applied to the plate?
Note 1: exercise is exactly as trivial as it appears. There are no tricks or hidden details that need strange inventions. the simple calculation necessary can be carried out in mind, without the use of any instrument.Note 2: who wants to post the answer, answer only yes or no, without (at the moment) justify it, so as to leave to others the possibility to try without conditioning.
