signs of roughness to indicate above the cartilage
  • Thread starter Thread starter Adahm
Adahm
I found some posts talking about the various signs of roughness to use, but I did not find solutions on how to manage the indication of the same on the inventor designs.
I would like to be able to indicate neatly without complicating my life, the signs of roughness inside and out the brackets as in the attached image (I took a random image from the web).
Has anyone found a solution about it yet?
thanks in advance
that designation is obsolete, the norm has been modified and inventor follows the same.
you will have a general sign and brackets with nothing between them.
I don't want to invent new symbols or use obsolete, I just want to be able to easily place those inventors on the cart.
click on the symbol button of roughness, click the location where you want to insert it (above the cartiglio, for example) opens the window where you define the symbol, give theok and the game is done.
And the parentheses?
Is there a way to place them in an orderly manner related to the cartilage and not to "crash"?
the brackets select in the window, if you want to place them in order I would do it in the table template, binding to a point.
I got here. It puts my parentheses with another sign of roughness inside.
Now I would like to be able to define the characteristics of this sign and add others if necessary.
you cannot define the sign inside because the norm does not foresee it and inventor is aligned with the norms.
the symbol is correct so, general tolerance out of brackets and the same indicate that there are different roughness indicated in the drawing.
would you have any reference with the new legislation?
