layer di default per quote guidate
  • Thread starter Thread starter DANI-3D
DANI-3D
I have always made a lot of use of the guided quotas both in the details and in the assemblies. Until now I have always moved them, later, by hand in the special layer called notes, which I manage with special macros to display or not information.
I would like to optimize the procedure so that the guided odds, when creating, go automatically into the known layer. in this regard I have inserted in the config.pro this instruction:
def_layer layer_driven_dim notes
def_layer layer_ae_driving_dim notes
I saved everything in a way, but it doesn't work, where am I wrong?
thanks in advance to the kind colleagues.
try to create by hand the rule, there are cases where the default rules do not transpose exactly the desired entities, made the ad hoc rule, it works much better.
I tried so, in the config:
def_layer layer_driven_dim quota_guidate_3d
and I work (cree 5.0): when I write down - quota and I create it in part 3d, I am created and correctly populated the quota level_guidate_3d.
try to comment on the second def_layer you impose or give it another value (e.g. note2) to see if it works
found, in the layer there was this rule: (name ==*) which obviously blocked the assignment. I removed it and now it works, but another problem was born, all the quotas, both those guided inserted in the model and those created in the table go into the known layer, does not feel this distinction:
def_layer layer_dim odds
Where do you put the quotas?
it is to know that to put the quotas both guided and the others has no added value - if not for specific organization - as the layers (show/hide) no longer manage the annotations/notes in 3d.
Have patience but ... I did not understand the explanation
when you put the quota in the layer, then hide the layer => the share remains on.
You can try
no, at least with wf5 is not so, if I hide the layer the quotas are not seen, even in the table.
with wf5, the layers commanded the 3d annotations/notes.
With creo, it's no longer possible.
