news nx1872
  • Thread starter Thread starter The_Matrix
The_Matrix
in about 10 days the nx1872 version is released (summer 2019 edition).
I make you a quick list of the news, in quite sparse order, regarding the most popular modules - general, modeling, assembly, 2d, pmi, mcd:
- nx is now available (from here on, eh) in token mode
- are available translators inventor, revit, navisworks, had, ifc (yeah!!), 3mf
- improve mcd simulation performance
- including reverse cinematics in mcd (as in animation designer)
- the "shadow lines" has been introduced, creating the 3D encumbrance curve from a point of view.
- in mcd you can directly use the new constraint assembly (i coupling)
- you can export movies in hd
A graphic "what's news" was introduced on the controls... the changing commands have a red ball on the icon
The new visual assist is expanding... the new help.
- file extensions have been grouped in file/open
- new couplers (gear, rack & pinion, cable) were introduced in assembly in addition to those already introduced in 1847 (joint etc)
- the minimal loading was also introduced for nx in native and not only under tc (minimal loading is the streaming functionality during the load)
- jt loading perfoarmances have been improved (3x in native, 9x under tc), making nx practically equal to tcvis in jttura
- improvement of the quality of the import step (I have a couple of use houses... as soon as the official version arrives, I try)
- it's easier to choose the pmi orientation plan
- possibility to set a color "fill" in the pmi so that they are more contrasted than the background and color of the objects
- support of section views arriving from jt and step
- in tdp (pdf3d and jt+pdf) the support for the various pmi views has been increased
- you can directly transmit the information of the new p&id module to the 3d
- possibility to export flat patter directly to tc
- improved the new fly-through
- the vr environment is now more fluid and responsive, as well as having jump features
- improved support for integrated nx awc
- ability to import variant expression from tc product configurator
- the revision rule is now available in the
- the possibility of using 2d textures to be applied on the model as 3d (the 3d is calculated on the basis of the gray scale)
- introduction of the "morph mesh", therefore, possibility to use a technique similar to subdivisions to model the stl (change of cage = change of thestl)
- new modes of "fill hole" on convergent
- fit surfaces supports multiple areas (yeah!!! )
- draw cage in realize shape. in practice it is possible to draw super interactively, the cage directly on a stl or other geometry
- command section tube in realize shape (yeah! yeah! yeah!). in practice create subdivision geometry by dissecting the sl
- hundreds of new use houses treated by blends, blend pockets and convergent modeling functions have been introduced
Good day
I know two types of tokens, the banking (hardware) and the computer, the "signed" tokens that replace the desired values faster
What do you mean by:nx is now available (from here on, eh) in token mode
Good day
to lick the mustache... :-) Are these new features available with the nx13300n bundle?
-- cut--
-- cut--
thanks matrix for these info!
are there brochures / videos about these new features?
Thank you!
means that from 1872 instead of buying imagines, as an example:
- 1 mach1
- 1 weld
- 1 advanced surface
You buy "tokens" and you can use modules until you run out of tokens... so you practically have access to all nx features within your token capacity
- 1 mach1
- 1 weld
Hi, this token thing intrigues me. I ask you a question: "In the office we have 4 mach 3 licenses. speculating that they correspond to 12 tokens, means that from the next update we could go back to use the welded (which before were not included in our mach3) using the token of a machine that at that moment is only using only the drafting? I hope I've explained well...
exactly.
you can use any combination of modules that does not exceed the token quota
[emoji849]sent by my col-l29 using tapatalk
what's new is where it's always been
WN.webpwe went from nx11 to nx1880 so I had to look at all the wns.
from what I saw news of a certain weight, for an average user, are:
the new measure command (nx12)
the open in window and the consequent management of the windows (always nx12)
the dmu (interesting)
all new features listed by @the_matrix are a 'bomb' but, according to me used by very experienced users and, above all, actually structured in a certain way.
I used the reverse mats. to stay open.
And the only place I didn't look at. . .[emoji849]I expected a txt file inside the installation package.[emoji3166]thanks for the right
