calculation sits oring
  • Thread starter Thread starter papero
not wrong, but the 12 kg are those that push only on the section of the o-rings.
If you didn't put anything, it's very likely that you might have problems.
So what do you suggest?
anti extrusion? Can I do a sketch of what you mean?
I'm sorry I couldn't answer before...
If the crown should not be rotated in dive, you must get a metal-metal line that contrasts the hydrostatic thrust before the crown goes to press where it should not. something like what you drew in #4.
