ale_.93
these days I had to perform a rupture analysis of a component to dimensional it so that it does as a weak element and breaks under a certain load. I worked in hypermsh with the optistruct solutor.
I obviously performed non-linear field analysis going to insert the curve of the material.
I interpreted the results going to see the plastic strain of the stressed section and the tension that came out so I made a somewhat (let me pass the term) "manual" of the result, going to compare these values with the curve of the material.
This is because in the result I have achieved convergence even in cases where I have found deformations and therefore tensions that exceeded the breaking limit. can you tell me if there is hidden in some cards how to set a limitation in terms of strain and/or stress?
