dotted lines
  • Thread starter Thread starter Rosty
Rosty
Hello everyone, I have recently found a problem in using autocad 2018.
dotted lines applied to curved lines and circumferences are not displayed. once assigned the style of line to the entity it is displayed however as a continuous line but, if the select, the selection shows the restraint.
Has anyone ever encountered this problem?
Have you tried to change the ltscale value?
if you attach the file you can make some verification
I tried but it doesn't seem to be a scale problem.
Here I attach an example, when I follow the blue selection the line is seen dotted but in reality it is continuous, also from the properties is treated and correctly in scale
I have also noticed that putting in a three-dimensional view the line actually looks treated
I opened it with drafsight and I see the drawing correctly. I'm trying to take a look at the carcad tonight.
I do not understand however that it is necessary to give the layer a style of line and then force the entity the line style of the object by attributing to it the same of the layer. to understand if you select the circle the style of line is not from layer, but acad_iso04w100.
try copying the circle on another template, sometimes it is a read problem of the line styles specific file
I tried to copy in another template but the problem still exists, although I open a new blank design and make a new circumference gives me the same problem.
only when I open the same file on autocad in mac the problem disappears automatically.
if on another template from the same result it is to set some system variables. this also explains why in another pc you see it correctly.
I noticed that if I imposed the view on wireframe the problem doesn't occur anymore, if I put on wireframe 2d it back. can you overcome the problem?
