fra_black94
Hello.
My problem is as follows: I have to export a drawing made in scale 1:2 on a pdf a4 sheet so that the size on the printed design is accurate (i.e. 1mm measured corresponds exactly to 2mm real, that the design center cad is in the middle of the sheet) despite it has lost a lot of time I failed to solve this problem. I tell you the way I used it:
How can I solve this? Thank you!
- I realized the design by inserting the real quotas in autocad, then 1mm = 1 unit
- I tracked a border indicating the sheet so that its size is equal to those of the a4 sheet multiplied by 2 then 420 × 594 units, I tracked the square edges of 20mm per side (they should be 10 but multiplied by 2)
- I went to print and set the values reported.
