create qr code bar code from text string -> table setting
reggio
hi, I have the need to insert a qr code barcode into the table (the "normal" barcodes we already have them with simple font).
of course we would like to avoid the classic create/copy/paste of various images at the table.
I was wondering if there is a macro or anything that can allow the creation of a qr code starting from a text.
Hello, Reggio,
a simple macro does not exist would be too trivial.
I have been able to develop a solidworks addin that creates the qr queues on the table, it is created at every creation of the table and is updated at every opening.
I say it updates because inside it can contain more customized properties of the component at the table, so to every change he remains always updated. the use of the qr code at the table has multiple applications, you can read it with the gun or with the cell phone, on the machine or in the office for the various needs.
my application places the qr code at the point where you want for each format (a4.a3,a2,a1,a0) with setting of the coordinates by means of a setting panel and depending on the "customer" in use (other application), you can have different positions for the carts of the various customers who are usually different by size and size.
As for me it is not a simple and pure macro, but an advanced application, because you have to have a flexible management of what you want to write inside according to the use you want to do and can implement it for future needs.
on this subject I have been able to develop in detail in recent years.
Hello, Reggio,
I'm sorry. jenuary He didn't think :p
ahi ... :eek: €€€€€€€
... but your application is not open and available, is it?? ? :love:
What are you doing? programmer or what? )
[I said:
What are you doing? programmer or what? )[/I]
I am a designer with passion for programming, otherwise as I can be competitive. . . ;)
If it was something recently you could do something useful to everyone,
but this is something I would say dedicated :geek:, see for example only the macro for the dxf exports of the sheet metal parts, each has its own requirement albeit a simple and scary macro born.
I'm sure my application would be good for a 30% of users, others would each have their own variant request.
and then behind there is all my know-how.. .
... ah, but if it is so little, I have the solution, you only help modena users who by name start with "regg" .. and others arrange;) ah ah ah ....
Other jokes, we only have to do with that part that allows to draw a qr code starting from alphanumeric input (e.g. www.miosito.it/cliente1/comm123/file123.pdf) in a random position, without any other, in fact after we will take the "Qr drawing" and place it in the file and at the desired point.
we don't even care to create it with the table, it could be good even with autocad2011, we just get a dwg or dxf with the "Qr drawing" to be able to manage ... (so as to avoid the various steps and inaccuracies of the images)
Do you think this can be feasible without getting hurt or losing too much time? :
So a program that creates a qr code image, then you arrange to insert it into the table of solidworks or in autocad, did I misunderstand?
watch this test video \test....
Yes so it is perfect, but not image, as I said, of creators qr of images there are millions, but the imputed images manage badly and give bad results ..
I need you save in dwg or dxf so that you can edit/use it directly on autocad
possible? :
I can't help you, the generators generate a non vector file image and it's not even a font.
fonts that write on qr code create a code for each single letter
extension free x swx that has a qr generator
interesting:
I never installed "extensions":
- Are they safe?
- do they install with a click or do you need anything else?
- possible uninstall? How? like other software or sw?
- Once installed, how to launch the qr generator?
Do you want to give me two straights not to go wrong?
gstarcad or zwcad having their qr generator
... maybe later, if I can't with the extension, I'll try them;-p
as you see in the autocad video is a non-parametric image,
to every shift of the coordinates you have to regenerate it otherwise the old coordinates remain.
they have implemented in autocad what I perform in solidworks boards only that updates to each opening in case it is linked to custom properties. the user must not worry.
I don't have swx right now, but I can't give you an example.
watch these videos related to the various functions of #taskhttps://www.youtube.com/channel/ucfjmsrpjgzdujn4hmy9ximg/videos
Okay, try again.
installed with a simple click,
just load one or more tables and go to search for the qrcode task, (for test I did only at home and loaded 2 tables without cartiglio and frame)
warns you that it will only work with *slddrw files,
... but throwing nothing works and says he couldn't run... :
(maybe due to cartiglio and missing frame? ...
