activation points intersection circle line
  • Thread starter Thread starter stefer
stefer
Good morning! I fear you with a little problem that I can't find a solution.
I attach a drawing first:
Cattura.webpthe problem is that I'm trying to draw a 3-point arc starting from a point between the intersection of the perimeter of the circle and a construction line. . but despite everything, the point is not activated and therefore I cannot find the coincidence. the line and the circle are on the same floor and are drawn from the upper face. Is there a system to solve?
Thank you!
steak
i.e. you draw a sketch point and selecting the three entities does not give you the intersection bond?
and why don't you concise the end of the line with the circle?
If the end of the line is bound to some outside of the axieme and you can't change it, I would design another line that starts from the center of the circle where the other part and give it colinearity or parallel, and then I would give it the end coincident with the circumference
the line is completely blue which means it has no constraints. drawing a line over another line is to complicate life; if you just can't put a sketch point (why can't you?) you insert a break by breaking the line in two
from what I understand a sketch point maybe you can put it, he believes you don't find the intersection snap
I didn't think... You're right. to the fact that I tend to always think like autocad... and so I expected that where the lines intersect, there is a snap.
However all this because I'm trying to create a sweep cut on a cylinder... that diagonal scenes... And I mean... I haven't done well yet!! But I keep trying.Cattura.webp
but did you do the allrials? internal ones, not those of youtube
That's right. I needed the snap to create the sweep profile.
There are also snaps, but I don't know if this is working
Yes but it is still little that I use sw and some automatisms I have not yet activated them... With a little patience, those will come.
They don't work.. the only way is how you said at the beginning thread, that is to put the end of the construction lines in coincidence with the perimeter of the circle!
Thank you!
steak
I have the same problem with snaps, they go pretty bad, I draw a point in the sketch, that takes the intersection no.
I tried today and it doesn't seem to me to function badly the snap intersection inside the sketch.
what must be remembered to do is to pass over all entities with active command; this because I suppose solidworks record the entities and deduce the snap. autocad in this is more immediate because it immediately reads the entities without need to report them
