ray mental material collection for 3ds
  • Thread starter Thread starter simcar
simcar
I realized this collection of various materials for mental ray found around the web and I want to share them with you.
materials are sorted in 13 categories which are:
car lighting
special effects
finishes
liquid liquids
organic materials
metal metal
Mixed
monochromatics
walls
landscape
flooring
land
textile fabrics
each material is accompanied by a preview image and reltive textures. These are complete materials, ready to be applied. the materials are more than 300 while the textures about 600.
have been tested personally by me on 3ds max 2011/mental ray 3.5 but most materials also work with previous versions.
Code:
http://www.fileserve.com/file/zx5gry8
but you can't download anymore? Why do you tell me he's gone? How do you do that? :
hi, the link is no longer valid, could you insert another one? thanks for the availability.
I already had downloaded, if the owner does not make you feel, tell me how to do that I pass them.
car lighting
special effects
finishes
liquid liquids
organic materials
metal metal
Mixed
monochromatics
walls
landscape
flooring
land
textile fabrics
Code:
I downloaded the collection and wanted to know, how do I insert the material in 3ds, if I open a folder of a material, I find:
2. .rt
and two folders:
1: materiallibraries
2.
I guess the file inside materiallibraries is the solution! ! ! ! ! ! !
Hello, everyone! Excuse me if I write in an old discussion some years...:redface: I downloaded these materials long ago and wanted to know how to charge them in 3d max. I'll explain better: if I upload the "mat" file from the material editor from this screen. . .Immagine.webpObviously if I load any of these "voices" gives me the black material.
someone can help me!! !
car lighting
special effects
finishes
liquid liquids
organic materials
metal metal
Mixed
monochromatics
walls
landscape
flooring
land
textile fabrics
Code:
hi, the link is no longer valid, could you insert it again? Thank you so much!
If you have a chance, go straight to vray. mentalray is now deprecated in the latest versions of 3ds max, and replaced first by iray then by arnold.
