add a given to the table obtained from formula
  • Thread starter Thread starter Usti74
Usti74
I need to add to the table a text where, with a formula (not necessarily created on the table), I indicate the weight of my particular sheet. being a crude, I would like to obtain it automatically using the specific weight data x its volume.
Can someone please help me?
try to put it asformula in the parameters and then make it comarise in the custom iproperty and from you can put it on the table
rename the two parameters of the base sketch from which you leave (I'm talking about the idea that then you go for subtraction of material looking at the immagin) in "base" and "alterity".
cin ilogic:
area = 1 parameter deleted
'as number
area = round((base/1000) * (height/1000), 2) 'rounding at a maximum of 2 decimal digits
then multiplies by the main extrusion and by the specific weight and get a parameter with the weight of the original.
at this point follow how much he wrote cast16
I found how to add density but it is possible to make a formula in the table text box. I have to multiply this data
