selection filter for size
  • Thread starter Thread starter Sp4rk0
Sp4rk0
good morning, is there a filter or method, to be able to select only the parts specifying the size? ?
for example I find myself a set with 80 tubes, I would like to select only the tubes with ø200 sp.20 to change the color, can you do it by filtering the parts?
for what I know you do: filters> advanced selection and in the curtain you get the various possibilities. the only one seems to me to filter through a custom property that contains value 20 and value 2
I can't find it, I have standard filters, I can select points, axis lines and more, but the advanced selection is not there!
I found, I try and see if I can then let you know, thank you.
no it does not work, I have tried various combinations, perhaps it is more complex than it seems.
Okay, well, thanks anyway.
