how to create dome not circulate
  • Thread starter Thread starter 9zyzz9
9zyzz9
Hi guys, I have to create a dome according to that sketch but I am from a still hour here, I have tried all of them, even the dome function I have seen, what gives me something is extrusion with sweep that in the fittings it blocks me. I don't know how to act, do you have ideas?IMG_20200216_142204.webp
what gives me something is extrusion with sweep that in the fittings I get stuck
without file, without property manager, without model image with sweep it is impossible to answer.
You don't understand what you're talking about, what does it mean to block them?
Maybe you want to do something like this?
it does not make me select more than a piece of curve in the extrusion with sweep, but I do not have straight parts and I have 4 fittings
because the path asks only one element (the input box is single) then you have to do a sketch of the path
But I have no straight parts and I have 4 fittings
and this from an image should be understandable?
Maybe with the geometry that I had, I don't know what
If you look at my sweep you will see that the radius tightens, this means that beyond a certain geometry the radius cannot be done and consequently by error.
error that if you are reported you have to report in the question otherwise you cannot understand what generates it.
I understand, thank you, the curved part I do so with the sweep, while the straight part I do it with basic extrusion so it does not generate any error. to me he only said "mistake in reconstruction. completion of the unsuccessful sweep operation" a little generic.
