save everything
  • Thread starter Thread starter 9zyzz9
9zyzz9
Hi guys, I did a whole of a solidworks engine by combining pieces, overall, unified elements. the problem is that I spread everything in folders,dextops or around the pc.I would have to bring the total on another pc, you know how I can save with some action the overall+all single pieces in one folder? If you can.
if you open the overall and make a simple save with the name of the automatic one you find also all the under assemblies and the parts of which it is composed
if I open it in a new computer only the total without saving the various components you say that it opens it correctly and I can open the components too?
I never tried but if you have the same software and the same version or more updated (no more obsolete) I don't think you have any problems because "get behind everything"
but the parts remain in the original folders scattered for the pc.
make the pack&go specifying to flatten it in the unique folder and zipping it.
do it directly from the windows folder with right button or from open file>pack&go
When I save from the management to my local pc, I save my father's assieme and find everything below (not as single files) as a single file I only have the set, but if I open it I see everything that is inserted there
What do you mean by management? a pdm?
that you do not carry behind the files that remain in the original folders, and that is what I wrote; if you see the references you will see what folders they refer to.
if you want to get behind the files you have to do it via pack&go
ah ok as you say you also see individually each file in the folder without opening the axieme and opening them from there... a pdm itendevo
I would say that you were vital to me, saved in a folder all the files and subfiles of the total
