home
  • Thread starter Thread starter mohammed.majdouli
if you talk about representing calpestium sheeting the burglary is something that must be modeled if strictly necessary because it is honest in terms of performance being. otherwise and prefer a graphic plot
how can you insert it as graphic plot? in the same way can you do for the blooming of stainless steel?
I take a photo from google or made to the sheet, save it and insert the decal on the bugged surface.
See you guide
I was referring to the insertion of the plots within the settings of the graphic appearancehttps://forum.solidworks.com/thread/34388.
attention that it is necessary to activate the real graphics mode, but as it is presumed to be a necessity by rendering is not a problem. if instead it does not serve to make rendering, but only for indication to other sockets (developers, customers, workshop...) visual that it is bugnata you can opt for other plots like that present in the second image
in the guide is explained how to create new aspectshttp://help.solidworks.com/2016/italian/visualize/t_creating_and_editing_appearances.htm
Good morning to all, yesterday I did not have the pc at hand to try to realize the look/decalcomania bloomed. I'm trying now to make it happen.
momentarily I did not understand how to insert the photo made to the sheet inside the appearance.
I am proceeding by attempts through the guides you provide.
thanks, a greeting
Andrea
I put myself in the trend to ask where I can download the aspects, in particular the mandorlato.
in my library is not there, and among other things it seems that the complex textures (such as combing or brushed) cannot fit them. only colors:-(
In theory, pull the image you prefer and insert it from aspects
