problem saved lock disappeared
  • Thread starter Thread starter Roberto377
definitely massive you are right I have perhaps explained badly ,in practice I created my design in the model space I made a block etc., then I saved it as a block to export , then I opened a new design I loaded my block into the paper space without putting it in the model space , I saved this as a model to load in the layout then from them when I need to load my drawing +cartiglio etc. I look for it in the layout model and the various
Sorry, but you keep messing with the terms. I know I'm pedant, but if you make an explanation for future users who have to solve a problem you have to be clear.
to explain to you I make the potential user, who knows two things on the cross, which follows your explanation:
then in the design space my teaming and then of this I create a block... I got it.
Now I have to save it as a block to export...ok, I save by name.. and what extension do I use? What do you mean block to export? and then I will see
I make my shelf design, now I have to put the square in the paper space, try with insert lock and use the saved dwg before... But why are there two blocks? One inside the other? there is what is called as the dwg and what I saved in the previous design. ..bhooo we go ahead
except as a model to upload it to the layout. but if except as model I use the extension dwt... Why then do I have to upload it to another design? How do I do that?
Do you understand that you made an explanation that has little clear points?
when inserting a dwg into another design this dwg becomes a block, if you in your dwg the square turned it into a block you will find yourself with a block with inside a block. Do you understand?
it makes no sense to insert a square in a design and save it as a model, that is, with dwt extension, and then insert it into a future design... are useless passages; you save as a model and use that pattern to make drawings. Let me explain better with an example: I create the massivonweizenspa.dwt model with inside the layout space my square, when I have to make the design of the shelf I will use this model that will already have the square and are in place, I do not have to insert any block of anything.
windows cannot be inserted in any other place except in the layout space, it is physically impossible to insert them into the model space, autocad does not allow you!
Believe me, I'm not the one who doesn't understand how to create a block and how it fits, how you manage model space and layout space, I just want you to notice that there are inconsistencies in your explanation.
I give you my explanation of how you should do:
1st in the design space the square and the cartilage; in order to insert the attributes I have to create a block, so I create the block of the cartilage, within in the edita block and insert the attributes. finished creating it save, I leave the building blocks and explode it. at this point except design as sqa4-cart.dwg
2nd I make a new design of a shelf in the model space.
3° in the layout space I insert block and select sqa4-cart.dwg and, if it appears, I fill the attribute list, otherwise I double click on the block and the compilation mask appears
4th always in the layout space I create a window to display the shelf
I would like to ask you more or less to do so as I, apart from exploding the block, I still apologize if I was wrong to use the terms if I made myself unclear, it's only a few days that I use this program, we hope that this post might serve perhaps someone, I think that maybe it can create confusion, let me know if better to delete it or change it to make it clearer.
That means you have a lock in the other... How do you edit attributes?
a normal user can not delete a post, even if it was opened by him; change a post is possible only within 15 minutes. further actions are possible only by moderators.
If you don't mind me, I'd like to ask you something about quotas, I'm always in good faith that through these posts you can help
the forum is also made to learn; if it is not inherent with the speech blocks open another discussion
bho makes me edit them, but is not that politely when you have a free moment you can make a little video to post as you do, or do you have whatsap? I would like to ask the Commissioner whether he is a member of the Committee on Economic and Monetary Affairs and Industrial Policy.
attach files that acts as a block and a drawing with the inserted block
you need zippers to attach them
Okay, thank you. at this point I ask another question: I can insert geometric tolerances, but I don't know how to put the reference datums. I can't find the icon. Where do I find her? Thank you.
Hello Masses. yes solved... I changed the manager's arrow. I don't know if that's how you do it, but it works.
thank you for what you do for us forum users.
I wish you good
