I'm sorry, I thought you had to post it in the most suitable sections.Why don't you open ten more identical posts?
answer none of the 2
has not been required to enter tolerances and functions. my doubt was on the quotation of the bevel in itself, because following the norm, he says to quote its length in axial direction, in this case however the bevel is perpendicular to the axial direction.Does it make sense to share with 2 decimals? is it a particular that should be measured with the micrometer? What functionality does it have? where are the tolerances?
if quoti with 2 decimals it is not clear how to size a particular.has not been required to enter tolerances and functions
I realized what you're saying to me, but the idea was born from having a triangular tip and going to beveled later, so the bevel is on the tip, not on the side dimensions. I probably complicated my life starting from the triangular tip and bevelling it. I could have achieved the same goal by betting sideways.if quoti with 2 decimals it is not clear how to size a particular.
However, the concept of quotation is wrong.
you do not quote the tip of the triangle unless you do the drilling of the tip at a later time.
the actual size, therefore without tip, at that point it makes sense to give the dimensions of the side bevels.
size 29,97 does not serve anything
neither. the long side and the corner... .Hello everyone, I wanted to ask you which of the two ways to quote the bevel on the left is more correct. initially the tip is triangular, then I performed a bevel. Thank you.
View attachment 57009View attachment 57010
with the quota from 44.42 one adjusts to buy the crude and is the leading theorist.
