configurations and save files
  • Thread starter Thread starter matteo.minghetti
matteo.minghetti
Good morning to all, I tried to find if a similar discussion had already been opened, but I found nothing like this.
I'll explain the problem.
I have a swx part file that contains "n" configurations.
Suppose the side file is called "parte.sldprt" while assuming that the configurations are called "conf1"; "conf2"; "conf3"; "conf4", etc...
what I would like to do is generate "n" pdf file and "n" file in dwg whose name would be:
"conf1.pdf" - "conf1.dwg"
"conf2.pdf" - "conf2.dwg"
"conf3.pdf" - "conf3.dwg"
Now, I ask you this, because first I don't know if you can do it.
the file name would be crucial, as this file would be hooked to an executable program (developed internally) of encoding that would be able to take automatically (after creation, of course) the file as long as it has this name.
Basically it is a very basic version of a configurator.
I ask you first if someone has already had similar experiences or if you can do (if with a macro or other methods).
I attach an image that can help clarify what I should do
thanks in advance
in the macro section there is a created by jenuary that exports pdf and, I think, dwg.
Take a look if you do what you ask
you mean this:
Yes. not having these needs I followed the discussion by curiosity, but without deepening it so I don't know if it does what you need
I try to charge her and see what she does. to the eye and cross I would say no, but I reserve to look better
Yes, I read better, it is a very well done macro on a double rescue both pdf and dwg.
My problem unfortunately is different.
can I move to "interesting macro?" or leave the discussion here? thanks in advance
try to add your needs to that discussion. Maybe jenuary comes out and takes a look.
I don't know anything about macro so I don't know how hard it can be to do as you ask
