undefined sketch
  • Thread starter Thread starter genesis1975
genesis1975
Good morning, I made a 3d sketch and then make a sweep and create a curved tube....before it was defined, totally black, but then when I put two simple sketch fittings here that I came back blue, undefined, and I can't get it back n1591950300287.webpI was... how would you do that?
Good morning, I made a 3d sketch and then make a sweep and create a curved tube....before it was defined, totally black, but then when I put two simple sketch fittings here that I came back blue, undefined, and I can't get it back nView attachment 58383I was... how would you do that?
ciao genesis1975,try to move the blue elements, dragging them with the mouse, in this way you will immediately notice which odds are missing.
I know that it is missing:
- a quota between the two lines on the z axis
- the position of the 633 long line (I imagine on the same floor as the other)
- the position of the arch
then:
-put the quota
- select top and line plan and place the bond on the plane
- select the arc and the front plane and put the parallel bond
- if still free to put equality between tilted lines
It would have been easier if instead of having the origin on the extreme point of a line had been in coincidence of the plan where the arch is located.
Maybe you could avoid 3d sketch by doing 3 normal and then using structural members instead of sweeping it as you would like to do
Yes, I also got there giving more or less the odds that you said... ..but it's a lot of effort, then sledding for two hours I got there. ..before making the two fittings was all black, then the thing complicated not little...between all the degrees of freedom that can have a line in space...but it complicated things to subdivide further by introducing the points of the chord...before it was in place, then if sw gives the black and it is not that I don't know... I don't imagine how you can do otherwise with 3 sketches and not even structural members know what they are....cm
probabilment ecol fare iraccordi has erased you some quota and bond and you have not noticed
I don't know what structural members are.
prove them because they are exceptional to make tubes and pits between them
attached, if it can be useful, an example of tube made with 2d sketches and structural element
