riccardo432532423
Do not blame him in the same ora?
Thank youSuppose you have a traction steel has a yielding load rs= 400 mpa,
to calculate the cut or twist resistance do : 400 x 0.58 = 232 mpa.
Of course, this value applies the appropriate safety coefficients.
they that I had written it....0,58 is 1/√3....a divided root of three.hi the project is finished, everything went well but I have to make finishings to expose it to the best,
in the formula of the diameter of the tree what is 0.58?
If you've both found them, it means you can use both.one thing I found two formulas for calculating dv in the sizing of disk joints,
one is 0.2*d the other is 2.2*d+50 what is the most right one for my case?
So you can't use the cutter?It's a round. the crude is turned back. .
you can use what profile you want and any size, but if you need to get a round object it is more logical to start from a round profile with the closest possible measure to the one to getuando must take the crude to make the
joint can you take it only of cylindrical form? Or even rectangular square?
What do you want to do with the cut?So you can't use the cutter?
Sorry the first question is pretty stupid. I'm pretty tired.hello thanks again of attention, when you have to take the crude to make the
Is it right when working to use the mill to make the joint?
Cosa?I wanted to do it.
I imagine you mean the areas indicated with the lines in red.these here plus the spake to make them join
Can't you see the picture?Cosa?
but then from full circle can not do everything in fresa?speculating to do it from full bar you can also do it all from fresa, obviously not manual unless you are the vest of the flyers![]()
