then, assuming that it is a cylindrical calandrate, I don't think it can develop as it is because solidworks develops only two things:
the system that can be valid I think is the reconstruction from scratch of the model, so you need to redefine the geometry and try to see if a subsequent development can go out, using a straight sacrificial flap.I tried with modeling v20 and couldn't, even with the trick you indicated.View attachment 59159the system that can be valid I think is the reconstruction from scratch of the model, so you need to redefine the geometry and try to see if a subsequent development can go out, using a straight sacrificial flap.
I fear it is not developed in a classical way.
I had the doubt that it was unfortunately so:I tried with modeling v20 and couldn't, even with the trick you indicated.
