working together propagated to the part
  • Thread starter Thread starter giorossi
giorossi
Good morning to all,
use inventor 2019 and I read in the online guide that the workings applied in a set cannot be propagated to the parts when they are opened individually or put on the table.
someone of you is aware of a way to overcome this thing that, in my opinion, is a lack not recently for such software.
gio
gio
the work together are those that are performed in the workshop after installing everything. It is therefore correct that the components reach the workshop without processing, which will be carried out in operation. and are only processing for removal of material. at this point the commands of together assume a sense in not propagating.
correct, but sometimes it happens that a processing must be changed of "level" for a choice of processing / cost 8 example holes on tubular then made to the lasertube and then to be moved from the level of welded to the single part in order to be able to generate a perforated step file
I do not discuss the usefulness that might arise. and if you then move the holes, inventor should recognize that on one part that work comes from a working together then eliminate it and replace it? fact is that it is made to do assembly work and must be used for that reason.
