solids
Bye!
at least in the 2016 version, the sample of the components in a section view is not stable. I'll explain.
in my table I create my section view, by default all sectioned components have 45° line sampling. Selecting the various samples can be modified for each component/body. perfect. sometimes, however, it is enough to move the section line to lose all settings of the fields (see section line shifts that are influential in the section view and therefore do not change the design). or even worse, if I make a table to multiple sheets sometimes it is enough to pass from one sheet to another to work on another view to lose the settings of the sampling.
Am I wrong something in my way of proceeding?
would it be possible to set up at model/part level what type of sampling should that component have?
