solokite
in nx can you change a feature (extended reference share) and see the result instantly?
depends... if the feature is the first of a thousand you'll be a little tired.
depends on where you go to change the parameters, whether the dynamic update mode is activated or not...
there are a lot of depends. So what version do you use of nx?
What exactly do you want to do?
those are all direct modeling commands! ! !like this thing in solid edge; modify the features already made by dragging faces without using commands synchronous nx
Good morning basketsHe sees that you don't know the terminology.
ask if you can change a feature instantly and show me a movie where you move a face but do not change the features.
I don't know what they're doing in siemens, but it sounds like a big mess.
in nx the direct modeling has always existed and they called it synchronous when they added to the m. direct the possibility to remove the story. then added the parameterization to the direct m. and removed the possibility to remove the story leaving the synchronous name.
If they did even worse, the first st was a mess.
I don't dilute myself so much because I'd do night.
What do you want to do? what is the result you want to achieve?
Sure, your instant 3d of solidworks do it with double click on the feature and you will see all the parameters of the feature that dynamically you can drag with the mouse to see the change.in nx can you change a feature (extended reference share) and see the result instantly?
Can you look at this?Hi.
the quota with value 20 I can change it dynamically, the quota with value 19 no; you know how to do it?View attachment 61204
If you double-click on quota 19 (I imagine a constraint distance) you have the ability to change dynamically.Hi.
the height of the extrusion I can change it dynamically (can I set a decimal scale also? )If you double-click on quota 19 (I imagine a constraint distance) you have the ability to change dynamically.
If I understand you want to do
Exactly what I wanted to do! hand workif the sketch is outside the extrusion you must edit him. (I use 1980).
double click > odds appear > double click on the share you want to change > shots
the extrusion share you have to change separately
If the sketch is embedded in extrusion, you have to double-click on extrusion.
the quota (in your case 33)
you have to select the sketch icon in the extrusion panel. odds appear as before. change. Get out of the sketch and you're always in the context of extrusion and you can change more.
If your question is "I'd like to have all the odds displayed at the same time and throw them to manazza individually", I think it's not possible
