orthogonal projection attached
I'm talking about this, don't I understand that that space of 12 is also present on the opposite side?
It's not there. If they had been there, they would have made you see it. However, it is not a "space"... call it a notch, seat, channel but no space, much less hole.
Yes, but that paper board is in reference to post #1
we order:
If you look at post 1 you don't understand if the hole diameter 14 is passing or not
If you look at post 24 the hole diameter 14 is not passing
